Cannondale FSi builds
Moderators: maxim809, Moderator Team
Vicpt
by Vicpt
And TUNE rims, along with SAPIM spokes.
gfeldy
by gfeldy
Vicpt wrote:And TUNE rims, along with SAPIM spokes.
Awesome!
~GFeldy~
S Works Tarmac w/ EPS
S Works Epic HT Blurple tuned
Kitsbow
S Works Epic Blurple tuned - Sold :doh:
FS-i - Sold
Scalpel custom - Sold
EVO - Sold
cerro
by cerro
The Tunehubs are really nice, lovely in blue. But not perfect fit on the new Lefty, doesn't they use the new wider hubs too?
Vicpt
by Vicpt
I didn´t knew, and thought the front hub was the same. But someone told me (in another forum), that the front hub is different, especial for this new Lefty.
archicoolaurel
by archicoolaurel
I'm still enjoying this bike even more with the complete AX wheelset !
Vicpt
by Vicpt
Hi, those wheels are great, but they cost half a bike. Anyway, great choice.
What weight did you achieve?
Best regards.
archicoolaurel
by archicoolaurel
Vicpt wrote:Hi, those wheels are great, but they cost half a bike. Anyway, great choice.
Best regards.
8.7 kg like this
Vicpt
by Vicpt
You ride a size L, isn´t it?
archicoolaurel
by archicoolaurel
Vicpt wrote:You ride a size L, isn´t it?
Medium
gfeldy
by gfeldy
Medium
She looks great archicoolaurel!
~GFeldy~
Kitsbow
FS-i - Sold
EVO - Sold
jcopland
by jcopland
Here is my latest Cannondale build:
Cannondale F-Si Carbon Team (L)
Removed:
XX1 32t chainring
2 x Avid HSX 160mm rotors
12 x Avid rotor bolts
Prologo Nago Evo X8 saddle
Cannondale Foam Lock On grips
2 x Inner Tubes
2 x Racing Ralph 2.1 Snake Skin tyres
Cannondale Coloured Seatpost Clamp
DT Swiss Rear skewer
White gear shifter outer cable
Added:
XX1 36t chainring
2 x Quaxar Iris Ultralight 160mm rotors
12 x MT Zoom Titanium rotor bolts
SLR Carbonio saddle
ESI Chunky grips
Enve Tubeless kit
2 x Racing Ralph 2.1 Evo tyres
Cannondale Black Seatpost Clamp
MT Zoom Ultralight Curvy Rear skewer
Black gear shifter outer cable
Garmin mount
Copter tape
Weight 18.7lbs without pedals (8.5kg)
Will upload pic once allowed to do so
jcopland
by jcopland
As promised:
jcopland
by jcopland
the_marsbar;
As I am unable to PM yet, here is the info re the size of the F-Si.
I am 6ft tall with a 33" inside leg and Large is spot on.
Having previously had a Flash Carbon 26, Flash Carbon 29er and Scalpel 29ers I can confirm there is very little in the length / reach of these bikes.
If anything, I would say the Scalpel was the longest and the Flash and F-Si's are very similar. It should also be noted that all of the bikes have had 110mm OPI stems with the exception of the F-Si, this is the stock 90mm OPI stem and could compensate for the slightly longer top tube you suggest?
It was my understanding that when the Scalpel 29er was developed the geometry had exactly the same contact points (with 10% sag on the suspension) as the Flash 29er so the Factory Team could easily transition between the two. My comments above would suggest the same.
the_marsbar
by the_marsbar
Thanks, jcopland.
I am currently running a 100 mm stem on my F29 (I'm 179.5 cm tall), but I would probably prefer a 90 mm stem.
If you say that you feel the same using a 110 mm stem on the F29 and a 90 mm stem on the F-Si, then I am thinking that the large F-Si will be too big.
DanW
by DanW
When I was choosing me new frame (not an F-Si unfortunately) I found the following site is invaluable for size comparisons and calculating the required stem lengths and height on a new bike to replicate your current set up: http://bb2stem.blogspot.co.uk/2011/10/s ... -v100.html (scroll across for the one titled "CALCULATE BASED ON PUBLISHED STACK AND REACH")
