Fuchs Stevens - getting around 3,6kg
70,8 from the last picture was to close, i could not resist and had to do something to lose 0.9g and come under 70g
Its really raw this derailleur but it works.
Impressive! You could probably lose another 0.3g by cleaning it
I think you can shave a bit the area around the main bolt like guy from this project--> https://www.bikerumor.com/2012/01/19/ha ... erailleur/
And make some cosmetic job with cage,to make it look "rounder,dont give me wrong but it look like painted in Paint
bikemaniack wrote:...it look like painted in Paint ...
Haha
Just had the joy of ordering the THM Clavicula SE
Ooohh that will be nice
There is an Ax Lightness Ax6000 fork on EBay right now. 220 grams or lighter with a cut steerer. Are you still looking for a THM Scapula SP fork?
BH Ultralight
Litespeed Ghisallo
Scott Addict Singlespeed
Cannondale Evo HiMod
Felt AR FRD
Litespeed Ghisallo
Felt AR FRD
Oh thanks i´m totally in to ebay today. just bought an Litespeed Vortex there....
Do you know how much weight the rider can have for this fork? Was it 90kg?
85 Kg for the AX6000 premium fork and the heavier version called the Helios is 110kg.
BH Ultralight
Litespeed Ghisallo
Felt AR FRD
Litespeed Ghisallo
Felt AR FRD
I get questions about the wire for the rear derailleur.
I made a hole above the derailleur bolt and made a carbonpipe which fits in this hole and even down where the housing usually gets in. In the carbonpipe there is even a liner and all together has 1,5g
With this i can have a really light housing and i do not need the wirestop at the frame any longer. saved me a lot of weight this system.
It was a Tiso from the beginning.
Changed
- complete carbon cage
- carbon pulleys
- all parallelogram pins to carbon
- one alu parallelogram part rebuild in carbon
- carbon screw
- some metal work
And yes it looks really raw but i do not care to much that i do the finishing
Changed
- carbon pulleys
- carbon screw
- some metal work
