Raw 2024 Propel
Maddie
by Maddie
And here's just a random raw carbon photo dump:
And as you can see on the pic below, there are plenty of "flaws". That's what happens when you remove ALL the filler and excess epoxy resin.
If you have been to a manufacturer of mass produced carbon frames, then you'll know that the workers are not oversensitive with their sanding equipment. And time is money...
eins4eins
by eins4eins
Seeing your propel, i regret using satin clear on my raw frame. Gloss fits the technical look much better, showing all the details.
minley1
by minley1
Maddie wrote:
Sat Mar 30, 2024 8:39 am
This looks fantastic, top job👍
Maddie
by Maddie
eins4eins wrote:
Sat Mar 30, 2024 9:58 am
That is true. The Venge and SL7 of my partner are both clearcoated with a satin finish (which is what she prefers) and the carbon doesn't pop as much compared to mine. It's much more subtle and almost looks like black paint.
Maddie
by Maddie
So for now I decided to not build a new carbon tube for the seatpost but to modify the original one. I'm not sure if it is strong enough in the areas where the rod goes through. It's possible that it will let go after some mileage. Time will tell.
That's the complete clamping mechanism including the chopped off part. Two thirds' weight of the seatpost lies there.
I made this aluminium rod without the use of a lathe since I don't own one :D But with a drill press, some drill guides and improvisation I made sure that the blind holes are centered and parallel. And then anodised the rod. Unfortunately, the pic is a bit out of focus. If you want to do this too, be aware that UD carbon parts don't like drill bits. I prefer to drill a very small hole and then enlargen it by sanding with a Dremel.
Then the most critial part, the sanding of the two half-moons. They need to be identical on both sides, otherwise the saddle will be tilted down or skewed. I started with a Dremel and for the last bit, I used sandpaper on an OD2 steerer that has the same radius like the seat rail clamp.
I shortened the seatpost tube and removed the paint. The whole seatpost without Di2 mount and race number mount is under 100g. That's not too shabby.
Final assembly with different yokes from Schmolke. If you don't need an offset seatpost, there's a way to save 100g without spending a lot of money. Provided you have the tools and faith in your own manual skills.
Always remember to use a good mask if you are working on carbon parts. And get rid of the carbon dust carefully. I'm not overprotective and cut a steerer without a mask but if you drill or sand for more than a few seconds, then IMHO protection is absolutely necessary.
Maddie
by Maddie
Unfortunately, the seatpost tube didn't last more than 50km. A crack formed and the aluminium rod started his way to the top. I realized that the saddle started moving around a bit and I immediately knew that the tube was starting to crack. This is not a complete surprise since there is no reinforcement in place.
I will build my own seatpost tube that is stronger in the necessary areas. But as mentioned before, this will take time.
Eterna7m
by Eterna7m
Hey regarding the seatpost - is this the one? And would you still recommend it ?
Just found this amazing item on AliExpress. Check it out! US $113.05 |
https://a.aliexpress.com/_EzYpnQ7
I have a pretty low seat height and don't want to cut off half off the original post. Might be a good way to save some weight.
Also interesting to see that your bottle cage doesn't sit flush on the down tube. Same here.
Maddie
by Maddie
Yes, I bought the Hylix seatpost from that store and it fits perfectly. 4Nm is enough and no creaking sounds.
mazador
by mazador
Awesome read and thanks for sharing. Looking forward to the remaining updates :)
Is the DR hanger a Sigeyi?
Maddie
by Maddie
No, it's from AliX. But you need to be careful with those, they are a bit sensitive when it comes to external contact (walls, floor, crash...) and tend to bend easily. But during normal riding, they are totally fine
iamraymond
by iamraymond
Hey Maddie, are you still running the Swissstop Catalyst Race brakes? What's your impression of them?
I'm thinking about ditching the Galfer Waves to something that can handle the heat from long/steep descents better. In my experience they were working fine in the winter, but as the ambient temperature is rising the Galfers just don't manage heat well enough. I tried the Swissstop Catalyst (non-race) in the 6-bolt configuration, but they were actually worse than the Galfers, I wonder if the Race versions in Centerlock are better.
Maddie
by Maddie
It's interesting you mention that Galfer rotors. I had the same experience as you last year. I cooked them on a very steep descent where I mistakenly took a wrong road with gravel. Since then, they were not the same anymore and as soon as I applied mid to max brake pressure, they squealed like crazy. Braking performance itself was still fine though.
The new Swissstop rotors are solid so far. I haven't tried them in the Alps yet since the long passes are still closed but from the descents that I rode this year, they are working just fine. Final judgement comes in one or two months though.
NiFTY
by NiFTY
Great build. Love a raw frame, have stripped an evo myself years ago, its a labour of love. Only change I would have made was a smaller giant logo on the frame but other than that perfection to my eyes, chapeau.
iamraymond
by iamraymond
Yup, the same experience. They were fine when new, but after I overcooked them on a steep descent the Galfers would start to make noise, then eventually start vibrating. It only happens on the steepest descent. They're perfectly fine for 90% of descents that don't require hard braking at every switch back.
I received the Catalyst Race (sames as yours, I believe) and I'll try them out for a bit. Hopefully they're better than the Catalyst Pro ones.
