S-Works Epic Evo
rear shock: Fox Float Evol Factory 190x40mm + harware ... 277g
headset: CaneCreek Slamset Alloy bearing + Extralite Ultrastar 1 1/8" ... 60g
fork: Fox F34SC 3-pos Remote 120mm (shortened steerer) ... 1.473g
suspension remote: DT Swiss Twinshot ... 26g
stem: Darimo IX2AL -25° 70mm ... 66g
handlebars: Extralite Hyperbar UD 700mm ... 95g
grips: Extend silicon ... 66g
saddle: Selle Italia SLR Tekno Flow Boost ... 97g
seatpost: YEP Podio 30,9x350mm shortened ... 322g
dropper remote: Vecnum trigLOC ... 19g
shifter: Sram XX1 AXS Hopp tuned ... 58g
RD: Sram XX1 AXS + Hopp + Extralite pulleys ... 356g
brakes: TRICKSTUFF Piccola Carbon + Hopp carbon Matchmaker clamps ... 320g
caliper bolts: Extralite Ti 4pcs ... 10g
cranks: SRAM XX1 SL Dub 170mm 3Bolt + InPeak + battery ... 366g
BB: CaneCreek Hellbender 70 BSA DUB ... 85g
chainring: Sram GXP 3bolt Boost 32T ... 59g
pedals: Shimano XTR PD-M9100S1 - Meti Ti spindles upgrade ... 258g
cassette: Garbaruk XD 10-52T ... 339g
hubs F: Extralite HyperBoost3 F 28d ... 75g
hub R: Extralite HyperBoost3 R 28d ... 153g
rim F: Duke Lucky Jack SLS3 ULTRA 28mm ... 281g
rim R: Duke Lucky Jack SLS3 ULTRA 28mm ... 284g
spokes: Berd spokes + straigt pull inserts (7g) ... 149g
thru axle: Extralite (28g) + Specialized (33g)
tires: Specialized Fast Track S-Works 29x2,3" ... 2x610g
bottle cage: Tune Carbon right ... 19g
Total: 8.820g
Amazing build
Wow, this is seriously cool, 8.82kg with a dropper and power! How do you like the Podio, is the drop sufficient for the kind of riding you do?
- robbosmans
- Moderator
- Contact:
Absolute dreambuild, really nice
