H A L E Y Road Titanium
Aloha from Maui
Sharing the new HALEY bike. Keeping things simple and classic with Mechanical + Rim Brake. Color and design inspiration from the beautiful Paul Smith designed 1965 Porsche 911.
Frame: HALEY Custom Road, 3/2.5 Titanium, T47 BB, Bi-Ovalized Top Tube and Down Tube
Fork: Columbus Futura SL
Headset: Chris King Inset 8
Wheelset: Caden Decadence 38mm carbon clinchers
Tires: Pirelli P-Zero Velo clinchers 25mm
Tubes: Pirelli SmarTUBE
Shifters: Shimano Dura Ace R9100
Crankset: Shimano Dura Ace R9100, 52/36, 172.5mm
Brakes: Shimano Dura Ace R9100
Front derailleur: Shimano Dura Ace R9100
Rear derailleur: Shimano Ultegra R8000 Medium Cage
Bottom Bracket: Enduro XD-15 (T47/68mm)
Cassette: Shimano Ultegra 11-34
Chain: Dura Ace/XTR
Power Meter: 4iiii left side
Handlebar: ZIPP SL-70 Ergo Carbon 40cm
Stem: ZIPP SL Speed 100mm
Seatpost: ZIPP SL Speed
Cages: Arundel Mandible
Bar tape: BURGH Cycling
Saddle: Prologo Scratch M5 PAS Nack
Pedals: Speedplay Zero Stainless Steel
Finished complete build weight 7.4kg
Chain: Dura Ace/XTR
That's a very pretty bike!
- Juanmoretime
- Administrator
Well done! I love to see titanium bikes. The color scheme is excellent. There are different copmponents I would have used such as eTap AXS. A ride report?
@Nixster...Thank you for your kind words. I added build dimensions in the post. This is my first bike with a T47 BB. It is a standard part of the HALEY package. Here is the information directly from the HALEY site...
"T-47 bottom bracket shell — this oversized option allows you to use a threaded bottom bracket for either 24mm or 30mm cranks. We've found this to be superior to any other threaded or press fit option. The oversized shell also allows for keeping electronic wiring internal. The shell also provides a larger surface area for welds."
As for the Shimano groupset, it is something that I have on other bikes. Shimano has worked very well and been reliable for me.
