It's obvious a lot of thought went into the stem/spacers/headset. The machined bore on the underside of the stem that allows the very top of the bearing to perfectly integrate is so well done. Especially when slammed.
Lots of little things..... the screws used for the derailleur hanger instead of hex head is just genius imo.
Basso diamanté super record eps 12 2021.
- wheelbuilder
- MrCurrieinahurry
- Moderator
The only problem I had was with the integrated bar stem combo as it wouldn't stay in place. The inside of the stem where it clamped to the steerer was only serrated and whatever I tried never gave me much confidence. Obviously as per with manufacturers in my stem length bars were to wide so went back to the normal alloy stem and the exs 150 bar which has been great and the bar offsets some of the weight of the stem
Basso Diamante rim Campagnolo EPS 12 Bora WTO 60's
Beautiful bikes, the red/white colour-scheme looks delicious.
I am not a friemd of integrated bar/stem Combos, they do look slick, but i rate maximum adjustability as more important than looks.
