Colnago arabesque
- MrCurrieinahurry
- Moderator
All talk without the pics to back it up
Sent from my MAR-LX1B using Tapatalk
- MrCurrieinahurry
- Moderator
Stop messing with us...
managed to get to 7.8kg
7D79DA7E-C720-424D-A575-285C080B2F57 by mark anderson, on Flickr
B0CF6C16-1C1E-43E5-8ACD-3070E58CF5EB by mark anderson, on Flickr
E3E3D68A-0885-4B0B-AA9B-1AB692AB3801 by mark anderson, on Flickr
21F8FA9B-C6C6-41B9-B6EB-7F4A4C9E0FA7 by mark anderson, on Flickr
41C51423-09D6-4F6F-A22F-9E03D4EBE476 by mark anderson, on Flickr
579334A9-951F-4FC1-9BA8-AAE2E91E6C8E by mark anderson, on Flickr
Colnago arabesque campagnolo super record 12
Colnago c64
Cinelli zydeco grx di2
Colnago c64
markyboy wrote: ↑Sat Nov 21, 2020 6:58 pmmanaged to get to 7.8kg
Colnago c64
Colnago c64
- MrCurrieinahurry
- Moderator
Wow looks gorgeous... I'd be tempted to find a slightly thinner stem if possible. How's she ride?
Not sure yet its wet outside lol re stem looking at a deda superlegerro rsMrCurrieinahurry wrote: ↑Sat Nov 21, 2020 7:01 pmWow looks gorgeous... I'd be tempted to find a slightly thinner stem if possible. How's she ride?
Colnago c64
Colnago c64
I don't like it.
I know. You've ruined it in my eyes.
But hey, it's your bike. You've build it as you like and that's all that matters.
The only thing I would say about the RS rather than the standard stem is that it's been slimmed down so much (more than the normal superleggero) that I was unable to find any carbon spacer with a small enough diameter not to encroach the edges of the top of the stem. What this means is that a fraction of the carbon spacer is exposed and your knee has the potential to slightly graze the spacer and does that scrape skin off! And this was with the genuine 3mm height deda ones which were the smallest diameter I could find. So it went under the stem. I know for some they say you should have a long enough steer tube to enable a small spacer above. So that's just something to consider. Otherwise for me personally the little bits of red bling slightly catch the eye when it should be taken up by the frame and all other components compliment that but it's your bike and hopefully it dries up to be able to ride itmarkyboy wrote: ↑Sat Nov 21, 2020 7:03 pmNot sure yet its wet outside lol re stem looking at a deda superlegerro rsMrCurrieinahurry wrote: ↑Sat Nov 21, 2020 7:01 pmWow looks gorgeous... I'd be tempted to find a slightly thinner stem if possible. How's she ride?
Yes the red bits were taken off my master so i will be looking to change them soon,i dont really want to get new wheels as these are a light wheelset but its those red hubs we shall see.c60rider wrote: ↑Mon Nov 23, 2020 8:55 pmThe only thing I would say about the RS rather than the standard stem is that it's been slimmed down so much (more than the normal superleggero) that I was unable to find any carbon spacer with a small enough diameter not to encroach the edges of the top of the stem. What this means is that a fraction of the carbon spacer is exposed and your knee has the potential to slightly graze the spacer and does that scrape skin off! And this was with the genuine 3mm height deda ones which were the smallest diameter I could find. So it went under the stem. I know for some they say you should have a long enough steer tube to enable a small spacer above. So that's just something to consider. Otherwise for me personally the little bits of red bling slightly catch the eye when it should be taken up by the frame and all other components compliment that but it's your bike and hopefully it dries up to be able to ride itmarkyboy wrote: ↑Sat Nov 21, 2020 7:03 pmNot sure yet its wet outside lol re stem looking at a deda superlegerro rsMrCurrieinahurry wrote: ↑Sat Nov 21, 2020 7:01 pmWow looks gorgeous... I'd be tempted to find a slightly thinner stem if possible. How's she ride?
As for the stem thats a good bit of info i will bear that in mind.Chain catcher black or silver?
Colnago c64
Colnago c64
