S-Works Venge by ChrisMTB documented detailed build
chrisMTB
by chrisMTB
Hi Weenies,
Not so long ago I posted my Canyon Endurance at 6.8kg’s. Now with the new addition to fleet, feeling that I still need a fast bike for the group rides and maybe a race here and there.
Here I present you all my new adquisition. A 2019 S-Works Venge frameset bare bones. By barebones I mean frame and fork completely naked without any small parts. It’s been a Journey so far ordering all the small parts.
Bike will be built with Dura Ace Di2, Pioneer Dual-sided and Hunt 5444 Aerodynamicist wheelset.
Parts have started to shop up.
I’m the meantime please find below pics of the frame and fork and it’s respective weights on a scale.
56cm Frame. 965 grams
Fork. 376 grams
chrisMTB
by chrisMTB
Headset Bearings - 43 grams
Compression ring - 8 grams
Top cap and bolt - 12 grams Image
Aero headset cap and spacers - 37 grams
100mm S-Works Venge Stem 100mm w/cap and cable clip - 217 grams
S-Works Aerofly 2 carbón bar 42cm - 230 grams
Front and Rear Thru-axles - 67 grams
Hunt 44 Aerodynamicist front wheel - 664 grams
Hunt 54 Aerodynamicist Rear wheel - 865 grams
Vittoria Corsa 25mm Front tire - 251 grams
Vittoria Corsa 25mm rear tire - 252 grams
Vittoria Latex 25mm Inner tube -88 grams
chrisMTB
by chrisMTB
Dura Ace Pioneer dual 52/36 172.5mm - 702 grams
Token Ninja BB30 to 24mm threaded - 120 grams
Supacaz tape - 107 grams
PYC Chain 116 Links - 236 grams
Sram Red 1190 11-25 Casette - 157 grams
Dura Ace 9150 Di2 Front Der - 106 grams
Dura Ace 9150 Di2 Rear Der - 196 grams
Dura Ace 9170 Di2 Hydro Shifters - 341 grams
Dura Ace Front Caliper with un-cut line - 162 grams
Dura Ace Rear Caliper with un-cut line - 162 grams
Shimano Di2 Battery - 50 grams
Shimano Di2 Cables - 33 grams
Shimano Di2 Internal Junction Box - 4 grams
chrisMTB
by chrisMTB
Waiting for seatpost and saddle to finish the build. Should come in next week.
Keep you all posted.
Cheers!
ryanw
by ryanw
Not being a dick, but it's not really "bare bones".
Frame has derailleur hanger, BB retaining split rings and bottle cage bolts.
Fork has expander in it.
So weights aren't true.
Decent weights though even with all the bits still on them. What size is it?
IG: RhinosWorkshop
chrisMTB
by chrisMTB
ryanw wrote:Not being a dick, but it's not really "bare bones".
You are right. Will weight the hanger and the split rings to get the real frame weight. Frame is a 56cm.
Fork is being used with the expander and already assembled the bike like 80%.
Getting there! already routed all the Di2 cables, hydraulic lines, installed bottom bracket and crankset.
Seatpost, saddle, connect the hydraulic lines and bar tape is what’s missing. Can’t wait to ride it!
Sneak pic
ryanw
by ryanw
Don't forget to peel off the "peel me" sticker under the top tube ;)
IG: RhinosWorkshop
chrisMTB
by chrisMTB
ryanw wrote:Don't forget to peel off the "peel me" sticker under the top tube ;)
Ryanw,
You have a good eye!
Hopefully ready by next week!
LeMomo
by LeMomo
Looking good.
Those expanders weigh 28g according to my kitchen scales - just to answer the above poster.
chrisMTB
by chrisMTB
LeMomo wrote:Looking good.
Thanks LeMomo! Gotta add it to the list
PedaleurPat
by PedaleurPat
Hi Chris! Do you have updates on the bike? Cheers
V35
by V35
Looking forward to the build, any plans to add weight weenie parts?
robertonavaz
by robertonavaz
Meanwhile mine has passed the 7kg barrier!
Red 22 etap
Farsport Fether 50mm
Enve raceday tlr 29mm
Power mirror sworks saddle
Favero Assioma
AliExpress bottlecages and garmin mount
Cannondale suede tape
Mucoff valve
Inviato dal mio iPhone utilizzando Tapatalk
