Kayrehn's Factor VAM disc build
Kazyole
by Kazyole
Damn, that Darimo bar and stem is clean looking. Needs a carbonworks Darimo mount though ;)
Kayrehn
by Kayrehn
Kazyole wrote:Damn, that Darimo bar and stem is clean looking. Needs a carbonworks Darimo mount though ;)
My raceware mount is 5x cheaper and only 2g heavier Image unfortunately I'm not a dentist Image
Kazyole
by Kazyole
Kayrehn wrote:
Wed Feb 12, 2020 5:58 am
Fair enough. I'm using a raceware one at the moment as well and it works well enough. And yours is nicely color coordinated anyway.
George46GR
by George46GR
Could you please explain why you choosed the Carbon-Ti hubs instead of the Extralite CyberFront/Rear SPD 2 ? They are even lighter than the Carnon Ti. I am a 85 kg rider and want to built a lightweight disk brake wheelset with every day use, NOT only races (I do note race.... yet....), thus they should also be durable and reliable. I was thinking of the Extralites CyberFront/Rear SPD2 hubs plus a parcours grimpeur 40 mm rim set (410 gr per rim). Could you please advise ? Thank you. Your built sounds unbilievable.....
2023 Cervelo S5, size 56, sapphire/ice
Klaster_1
by Klaster_1
George46GR wrote:
Fri Feb 14, 2020 8:08 am
Might not be compatible with Berd Polylight, I commented on this in my thread and maybe here too.
Kayrehn
by Kayrehn
George46GR wrote:Could you please explain why you choosed the Carbon-Ti hubs instead of the Extralite CyberFront/Rear SPD 2 ?
Mainly cos I like the bling Image Also, my wheelbuilder would advised me to use the HyperRear 2 mtb hub instead as it has better spoke tension balance between left and right flange. My Carbon-ti is still heavier than the HyperRear by about 30g but... the bling...
KCookie
by KCookie
Kayrehn wrote:This finally arrived after 3.5 months. Unfortunately I don't know how to remove the original ones (any help?) and so can't do a weight comparison.
All components in, build can finally begin! Maybr one last spin on my Fuji before I take it apart; I am sure I can feel the 0.5kg difference between the two, and might miss the feeling of lightness. Image
15.5g saved over the original clamps! Image
Think I might have to get these clamps to when I order my stem.
My Schmolke clamps were 7.2g. So more grams will be saved.Image
Sent from my SM-G960F using Tapatalk
Kayrehn
by Kayrehn
Do that and you'll be hitting peak weight optimisation Image for me it's more of small incremental weight savings like these and tesa tape for the bars.
I decided that heat shrink hoods will be a bit too challenging due to the fact that the hydraulic shifters have a lot going on to do a neat even piece of work.
young
by young
what size frame? my 49 frame set weight is 707g and 286g (cut)
also are you running 38cm bars and 120mm stem
I have very similar weights for my darimo.
Kayrehn
by Kayrehn
Size 54 frame, 38mm bars and 130mm stem. Hopefully I can ride it in Sept and report back on feel.
survivor
by survivor
It's September and we are expecting a ride report :mrgreen:
Kayrehn
by Kayrehn
1st proper shakedown ride on today - with most of my parts from my previous Fuji, it felt pretty much the same except that the disc wheels definitely felt stiffer. It took so long to build up because the LBS cut the steerer too short the first time round and the replacement fork took 7 months to come (during this time Factor came up with 3 new reiterations of their current stable and 2 new models). Am extremely happy to have a quiet drive train and braking system (which was a very pleasant surprise after reading squealing disc stories). This should last me for quite a while.
Oh, 5.22kg there with everything that's bolted on. My only disappointment ImageImageImageImage
LewisK
by LewisK
I'm not sure if I'm more impressed by the build or the fact the bike shop managed to cut your forks too short 😳
Beautiful bike!
Klaster_1
by Klaster_1
Kayrehn wrote:
Sun Nov 15, 2020 6:20 am
You mean with two bottles, bell and lights :shock: Congratulations on finishing the build. Man, I need to get an Aethos frameset 😅
Mr.Gib
by Mr.Gib
Nice bike (a bit loud for my tastes) and good weight of course. The LBS messing up the fork cut boggles the mind.
Building a rim brake VAM of my own soon. Will be very boring by comparison. I am on the fence about the Clavicula. I just can't tolerate bb/crank noise. Does the THM crank/bb combo feel solid? Silent? I fear if I can flex it too much it will ultimately start to make some noise.
Any more to say about handling, comfort, etc?
