Colnago C64 Mapei 48s (rebuild with SR12 EPS)
awesome guys .. I just mount the Veloflex TLR tires and took me less than 5 mins with my bare hands no tire lever =)
I just need to find a compressor in inflate them and do sealant.
2020 Colnago C64 Mapei-SR12 EPS-WTO 60
2021 Basso Diamante SV-SR12 Disc EPS-WTO 60
2023 Colnago G3X-SRAM AXS Force-Levante
New Shoes and rubber - First time running tubeless and I'm sold !
#campagnolo #colnago #colnagoc64 #Mapei by nismosr, on Flickr
Hey Nismor: if i remember right, the warning sticker has to be on the left side while riding; i think your front wheel is installed wrong; check the brake surface; ACE has one direction only, there are channels in the brake surface
When installed correctly, the AC3 grooves should run in the same direction as the rear. Also the bearing preload adjuster is on the left side for both front and rear. And the “USB” stickers on the hub should face the same direction, so that they can be read when standing behind your bike. The warning stickers were both on the left side of the rim on my WTO’s but not on my Bora Ones.
It's all downhill from here, except for the uphills.
I just follow what the rear look like and thats what I did in the front but i'll check it again tomorrow morning before i head out, Thank you for the warning!
Love the look of clean gumwalls. This bike looks so damn good
I was looking at my thread and missed this one .. I'm guessing Sychen you're Japanese or maybe can read, because thats the company motto.
Thanks Oneil , I'm really loving the wto with Veloflex Corsa 28mm and tubeless set up. big difference with the lightweight tubular.
Fog man looks like someone is new or forgot to read the manual at Campagnolo but this my set up is correct, I matched the direction of the rear ac3 to the front. the preload is on the right and the USB sticker is backwards when you read it when I'm behind the front wheel.fogman wrote: ↑Fri Jun 19, 2020 11:35 pmWhen installed correctly, the AC3 grooves should run in the same direction as the rear. Also the bearing preload adjuster is on the left side for both front and rear. And the “USB” stickers on the hub should face the same direction, so that they can be read when standing behind your bike. The warning stickers were both on the left side of the rim on my WTO’s but not on my Bora Ones.
Rear Wheel
Ac3 by nismosr, on Flickr
Front Wheel
Hub
good to hear. I have a pair of WTOs, only 45mm, sitting in the closet waiting for a stelbel Ti9 frameset. I need to PM you about your thoughts on Cipollini....
