Cervelo S3 Disc - New DA R9200 Rebuild + Pics + Build List (Page 7+8) - New Alps/Seatpost Weight 6.62 kg
scottydonald
by scottydonald
looking great; i really cant wait to get the DA12 stuff on my bike; i have been toying with the idea of replacing my frame to an S5/SL7/SLR01 but the frame is just so good that i think i will wait another year and see what the next iterations of the S5 and SL8 are like.
With your Power Meter i would just got the peddle route to get your bike weight down!
m66
by m66
Looks great! One thing - your build list says 109 links. Should be 106?
stevec1975
by stevec1975
Marginal Gains..
@Lucendi made some cool 3D printed things for my bike. Top skills.
Replace the aluminium stem cover (serves no mechanical purpose, everything is within the stem) with a 3D One
The round thing in the pic below
Saving a massive 6.2g - (Al 8.5g - 3D 2.3g)
Replace the Carbon Bar End plugs with 3D printed ones
Saving a massive 1.9g - (Ca 4.7g - 3D 2.8g)
scottydonald
by scottydonald
stevec1975 wrote:
Wed Feb 09, 2022 2:35 pm
Marginal Gains..
do you think he would make a stem cover for me? my one is slightly threaded.
Lucendi
by Lucendi
You are very welcome! The top cap and bar end plugs look great on your bike! :)
Bien
by Bien
stevec1975 wrote:
Fri May 21, 2021 9:10 am
I got the last 2 the guy had (had to buy it in a pair, so I do have 1 spare). If you are in the US you will be able to find it somewhere, but minimum order quantity is usually quite high.
I can sell my spare with the corresponding Ti stem clamp bolt M6x45mm if you are interested? PM me
Hi! I have the same bike model and was hoping if I can buy these bolts? Thanks
Current weight, 7,9kls
Full ultegra
Full ultegra
Bien
by Bien
stevec1975 wrote:
Wed May 12, 2021 12:08 pm
So...
Some updates, as part of my yearly strip and rebuild..
Cranks:
Sanded/Polished Quarq Cranks (The logo's have always annoyed me!)
Savings 4.3g
Stem:
After conversations with Cervelo, who advised it was OK to cut down (as you do when you buy a smaller than 54cm frame), I removed approx. 25mm of the Quill.
The stem weight went from 234.6 to 218.2
Changed out the M5 x 100 Compression bolt and the M6 x 45 stem bolt for TI versions (after much searching for suitable replacements)
Compression Bolt: 14.6 > 7.7
Stem Bolt:11 > 5.9
Quill Removal: 16.4g
Bolt Changes: 12g
Total Savings 28.4g
Bars:
Removed approx. 20mm from both ends (have never grabbed that part of the bar)
272 > 263.2
Savings 8.8g
Cassette:
Dura-Ace CS-9100 11:30 > BDOP 1 Piece Steel 11-28
206 > 179.5 (185.7 with Lockring)
Total Savings 26.5g
Still to come, Wheels and a few other bits, also doing a bit of friction reduction at the moment..
Sorry,
Do you have the DIN for the Bolts? Thanks, I am having problems looking for them here in Germany
stevec1975
by stevec1975
Hi the bolts are specified in the S3 Manual:
The stem expander one is m6 x 45 (1mm pitch)
The headset compression one is M5 x 100 (0.8mm pitch) - I sold my spare one of these + they are fairly hard to find..
Bien
by Bien
Hi! Thank you for the reply.
Just one question, do I still need the m5x100 if I cut the Stem 25mm? Thanks again
stevec1975
by stevec1975
Yes, the fork has the wedge component, cutting the stem removes the part that the fork doesn’t wedge into, therefore it makes no difference to the bolt lengths
Bien
by Bien
Hi!
Im breaking my head looking for the m5x100 titanium. Any leads? 😂
Thnx
stevec1975
by stevec1975
So updated a few parts..
Changed out the GXP Crank Arms to DUB (and sanded/polished to remove the Red logo's)
and the corresponding change to BB as well.
Total Saving - 119.4g
Added a CS OSPW:
Total Gain 27.9g
Plus changes to Stem Cap, Bar Plugs, TI Bolts and adding RS-801-S Sprint Shifters
And now, finally, it is UCI Illegal!
Nice.
scottydonald
by scottydonald
wow. looks aesome.
What is the total weight of the crankset?
stevec1975
by stevec1975
636.2g for the DUB Crank (vs 727.4g for the GXP version) + 28.2 saved on the BB
drumjdds
by drumjdds
unreal what you managed to do, fantastic build! how does she ride?
