Hello all,
I'm looking at the above shock (190*45mm metric sizing, as shown here https://www.tradeinn.com/bikeinn/en/roc ... lsrc=aw.ds). Can anyone with one, or with a similar model of SIDLuxe shock, please measure the barrel diameter for the main body of the shock - i.e. the main wider section above the smaller end where the piston inserts.
It's replacing the FOX Float DPS that's currently clashing on the lower wishbone of our Durham University Solar Car - not the usual use but superlight MTB shocks are brilliant for superlight solar cars!
Thanks!
RockShox SIDLuxe Ultimate RL Shock Diameter
Check the aircan dimensions in the spare parts catalog. That might give you some ideas.
https://www.sram.com/globalassets/docum ... atalog.pdf
