Scott Spark RC SL 2022 axle lever
AED
by AED
Long shot, but I can not find anything online regarding this, I suppose, quite rare problem:
There is a lever in rear through axle which is removable, however it IS NOT suitable for a front FOX axle, therefore additionaly another multitool (or 6mm tool) must be carried. Have anybody riding this bike found any solution to avoid bringing multiple tools?
this one: https://r2-bike.com/SCOTT-Thru-Axle-Spa ... -178x13-mm
btw it is incredibly annoying to find such things on most expensive MTB you can now buy :shock: :shock: :shock:
freepk
by freepk
@AED just remove this lever at all ) Use only multitool?)
TheRookie
by TheRookie
This is the weightweenie website and you want to use a an overweight axle?
The rear is provided by Scott for their frame and the front by Fox for their fork, replace both with a lightweight option using a hex tool.
snaxez
by snaxez
Fox kaboolt is 6mm as well, why cant you use the scott handle?
AED
by AED
snaxez wrote:
Thu Mar 30, 2023 12:26 pm
There key is very long (6mm+5mm+hex) and it does not go inside the fox axle until the 6mm which is at the handle :(
cerro
by cerro
freepk wrote:
Wed Mar 29, 2023 7:25 am
best solution. Levers are just ugly (and heavy)
