Scalpel HT 120mm Fork
LedZeppelin007
by LedZeppelin007
Having recently had a build get out of control and needing money for some family stuff, I bought a “sensible” MTB, a Scalpel HT 4. It’s nice! However, wanted to upgrade the fork and, since I have a Pike 120mm lying around, thought I might throw that on there.
The bike is only rated for 110mm, though, with a crown to axle length of 530mm. The Pike is 120mm and has a crown to axle of 540mm. I called Cannondale and they quoted out of the manual.
The other consideration is that it would add a little weight (I don’t care that much), and would slacken the geometry a bit more.
What are your all’s thoughts? Dangerous? Bad idea?
santanacorreia
by santanacorreia
Always start with the why
Why do you need extra 10 or 20 mm?
You ride xc then I would not do it.
You ride trail get a fs or a ht for proper riding.
My e cents.
Enviado do meu iPhone usando o Tapatalk
freepk
by freepk
@LedZeppelin007 you can spend extra 10mm for extra sag )
MikeMoore
by MikeMoore
Run a touch more sag for a more supple fork. Sorted.
Weight 74.4kg, FTP 303W => 4.04 W/kg
Retired Bikes
Custom 650B Kingdom Double9
Kinesis Aithein / Kinesis Racelight 4S
Current bikes
Reilly Spectre / Cervelo R3
Pivot Les / Pivot Mach4SL
Ventana El Conquistador
