Santa Cruz Blur XC - TR shock
la85
by la85
Does anyone know if the 2023 Blur XC RockShox SidLuxe Ultimate 190x40 can be made to 45mm? I.e more rear travel?
Cheers!
TheRookie
by TheRookie
Ignoring the IF it can, would the rear wheel hit the frame with 12.5% more travel?
I know the TR versions have a 190/45 but nor sure if there are other changes to suite.
The SID can definetly be had in 190/45 so I suspect the 40 has a travel reducer fitted which are increasingly common these days.
TwincamRob
by TwincamRob
As far as I know the frame and rear triangle are the same on the Blur vs Blur TR, only difference is the shock stroke. Here's some good info with pics on the spacer removal... https://www.mtbr.com/threads/new-2021-s ... t-15663556
la85
by la85
TwincamRob wrote:
Wed Feb 15, 2023 7:21 pm
Thanks heaps mate!!
