Yep podio dropper post
Michaelhumpal
by Michaelhumpal
What's your long term results like with the yep? I had the alloy collar come apart on ride 2 and upper stanction now has play after a month.
rapsac
by rapsac
Mine is ok, the collar is handtight (like Vecnum posts are too) and should be checked every couple of rides. Play is minimal on mine, much less so than on my Transfer SL which was wobbly to say the least.
Michaelhumpal
by Michaelhumpal
rapsac wrote:
Sun Feb 12, 2023 9:21 pm
Can you post a pic of the collar unscrewed? I think there were alloy threads glued to the carbon lower shaft. Mine came unglued and I think are stuck in the collar.
rapsac
by rapsac
Will do next weekend. Yep has excellent warranty afaik, why not contact them?
Michaelhumpal
by Michaelhumpal
rapsac wrote:
Wed Feb 22, 2023 11:19 pm
I got 1 response to bleed the post. Hasn't replied to further emails.
rapsac
by rapsac
As promised
scant
by scant
my transfer SL was developing a lot ot movement, so I put it in for a service. the upper stanchion section was replaced with a newer version which has significantly less movement
Michaelhumpal
by Michaelhumpal
rapsac wrote:
Sun Feb 26, 2023 4:44 pm
As promised
Thank you - as I suspected. My threaded collar broke away from the carbon shaft.
rapsac
by rapsac
Sounds like a warranty issue to me?
