Lux Build: Send help!
eins4eins
by eins4eins
My Lux Team CFR size M was 10.1kg out of the box, so without pedals, bottle cages, etc.
slightly under 10kg ready to ride now, but changed some parts
zscs
by zscs
greatstewie wrote:
Tue Feb 07, 2023 2:58 pm
hey zscs so the bike stock is 10kg?
I measured 10.08 kg out of the box. Size L
greatstewie
by greatstewie
ok ty
zscs
by zscs
eins4eins wrote:
Tue Feb 07, 2023 3:12 pm
Have you found the place of the spacer, that you mentioned on mtb-news.de forums? :)
eins4eins
by eins4eins
I think it was just a part laying around in the workshop and not part of the Lux
zscs
by zscs
On rough terrain, sometimes I can hear a rattling noise from the area of the rear hub. Took me a while until I found that out, it is actually a lever of the axle, which can a little bit knocking the inner side of the hollow axle (despite of the little rubber parts).
My Lux CFR came with this axle: https://www.canyon.com/en-hu/gear/bike- ... 10452.html
So I would like to buy a simple replacement axle which doesn't have lever.
Do you know, any brand offers a 100% compatible axle to this frame?
I tried to look around and found that, this has a Syntace-like cone end at the brake-side and must have a Sram UDH-compatible thread on the other end but I found only ~3-4 mm shorter axles so far, which can be compatible.
At Canyon's site I can see that, 2021- Excess CF, SLX and CFR models also uses this axle.
zscs
by zscs
Cool, thanks! :) :thumbup:
I have an up-to-date pic also (sorry for the quality, took it too quickly yesterday). Mainly equipped with the original parts, except for the Power2Max NGeco power meter and 70mm PRC stem + Berg 760mm handlebar. Also an old-school dropper installed, which is a 385/125mm 30.9 KS Dropzone (yes, a non-remote one! :D ).
Okay, the shock has been also changed to a non-remote SIDluxe (which has a slightly more progressive tune than the original remote one, with 1 volume spacer and 2 shims also different inside). Excellent climber, even in non-locked mode! :D
jfranci3
by jfranci3
zscs wrote:
Wed Apr 05, 2023 8:09 am
You can get that cone seperate. I think Specialized (Epic / Chisel / etc) uses the same axle and some measure wight and without the cone. Are you thinking 148mm is the size or did you measure it? It should be 148mm + ~10-12mm on each side for the frame droupouts, so you're looking at a 166mm axle likely. Measure your frame dropouts thickness on each side + 148mm + ~1mm for the cone.
I think Canyons axle is the same as this https://www.rapilock.com.tw/en/product- ... e-147.html
zscs
by zscs
New Lux WC CFR LTD comes with XX SL (including power meter) and new SID SL, etc. ;) https://www.canyon.com/en-hu/mountain-b ... /3512.html
Snabb
by Snabb
zscs wrote:
Fri Jul 28, 2023 1:33 pm
Love it ! But they are getting pricey!
Ride lots!
