Hey everyone.
I have two wheelsets, one with a DT350 and one with a DT240exp.
I want to know if the free hub body is interchangable between the two hubs so I can swap the cassette between wheelsets without having to pull it from the free hub. I have trialed it and it appears to fit and work but wasnt sure. I also wondered if the ratchets are interchangable between the two. 36tv54t
Cheers!
DTSwiss Hubs
I have heard sentiment that echos your trial, the freehub bodies should be compatible, but you should use the respective ratchet rings with the hubs.
