Help on brakes - MVDP Canyon frame - Sram Brakes
Hey guys.
New on this mtb scene and actually on disc brakes. Bite the bug and sold my trusty pinarello f8 and starter mtb for this beautiful frameset
https://www.canyon.com/da-dk/mountain-b ... enfarbe=WH
I will be putting on DT Swiss XRC 1501 on it and Sram ultimate G2 disc brakes.
But witch size rotors do i need? And do i need a adapter on the rear? and finally 6 bolt or center lock? Damn feel like a total newbie.
Appreciate your help
Most XC guys run 160mm rotors, but they often weigh 50kg so it might not make sense for you, what's your weight?
Double that. hahahahaha. Sooo...?bikewithnoname wrote: ↑Wed May 26, 2021 6:44 pmMost XC guys run 160mm rotors, but they often weigh 50kg so it might not make sense for you, what's your weight?
Ok, so I would personally say 180FR and RR but it looks like the Lux is built for a flat-mount rear brake and 160 rotor (and looks super neat).
I'll have to defer to someone that's seen one in the flesh as to whether a 180 would fit in terms of clearance or indeed if a post-mount caliper would fit (I think G2's are post mount?)
Thanks!bikewithnoname wrote: ↑Wed May 26, 2021 7:01 pmOk, so I would personally say 180FR and RR but it looks like the Lux is built for a flat-mount rear brake and 160 rotor (and looks super neat).
But when you see the picture on the website? Doesn't it look like an adapter is mountet on it? Flat to post mount?
- robbosmans
- Moderator
- Contact:
Why Sram Ultimate G2’s? a bit overkill for an xc bike, the level ultimates would be plenty.
Depending on your weight 180F and 160R is fine.
The adaptor probably comes with the frame
I seem to brake alot and i'm a heavy guy.robbosmans wrote: ↑Wed May 26, 2021 7:17 pmWhy Sram Ultimate G2’s? a bit overkill for an xc bike, the level ultimates would be plenty.
Thanks! Do i need anything for mounting 180 in the front? And 160 in the rear? Or would it just fit? And was centerlock the way to go?
- robbosmans
- Moderator
- Contact:
For the front you are going to need an adaptor like this one https://www.bike24.com/p2131481.html
If your wheels are centerlock just get some centerlock discs
Did buy the centerlock. Everything is sold out at the moment.. But my wheels has the adapter, so let's see.. I can give 6 bolt a go next time.
From memory, the 6 bolt rotor sits on 6 pegs in the adapter. This fixing is not as secure as using bolts, so to prevent any play between the rotor and adapter, I filled the gaps around the pegs in the holes with epoxy resin.
For sure it will make it more difficult to disassemble but how often would you need to do that?
