Which would you pick? Thru-Axle rear or QR and $100 in your pocket or Hydraulic Disc Brakes+QR?
1 + disc.
no doubt, yes!
I would also go with thru-axles + discs if possible. The latter hat to be flat mount.
You asked to a reasoning, so here it is: in my opinion, thru-axles will replace QR mid-term on all higher end bikes. Thus if you are getting a frame custom made and plan to keep it for longer, you will simply have more flexibility in the future in terms of wheel choice. Plus, thru-axles and thru-axles optimized hubs can potentially made lighter than a QR system (same reasoning as for the larger spindle size in bottom brakets).
joeg26er wrote:Hi -
I am talking to a custom builder for a gravel/cross bike and they gave me this choice
Which set up would you pick and why?
1) Thru-Axle rear or
2) QR and $100 in your pocket or
3) Hydraulic Disc Brakes+QR?
Through axles both front and rear...
full Hydralics for road, gravel or cross: No.
Hydralics are too complicated to fix enruote and addds a life with endless bleedings and complicated re-wireing. Go with TRP's cable actuated HY/RD if you can live with the weight, braking power and control is sufficient fr any drop bar bike use, for an enven less complicated and lighter setup: go With TRP's dualpiston mechanical Spyre's. For both: go with the beste cables and housings outh there: DuraAce, Jagwire or better.
At first i tried my HY/RDs with Campy cables and housings but they compressed way too much (it has never been a problem with my campy rim brakes), a pair of Dure Ace cables and housings solved the issue.
mvh. Morten Reippuert Knudsen @Merlin Works CR, Chorus 15, Reynolds 46/66
joeg26er wrote:Currently Thruaxles and hubs thereof are heavier than QR AFAIK? Please correct me if I am wrong?
Hubs: not, they should actually be lighter.
Hubs+QR vs HubsThruaxles: they can be equally light but be prepared to shell out a major amount for the lightweigth thru axles.
QR Frame/fork QR vs Thrugh axle Frame/fork: QR Frame/Fork will be lighter.
Still, id say if you want discs go for Thrugh axles both frot an rear. It will bake your life easyer.
Tomstr wrote:
For my use, gravel grinding and some CX, QR's and discs do nicely.
That's my pick as well. Hydro and QR ! I was not shy to get a frame with QR, outer cable routing. simple to maintain in the gravelcx dirty world. Hydro for everything it does great.
