I thought I'd start this after scouring all corners of the internet for different options for a new build I'm doing. Information on dust cover dimensions and stock spacer design seems hard to come by. Making it hard to tell if a non-standard bar and stem will work nicely or a 3D print option will be needed.
Chapter2 Koko/Toa
Dust cap
Stock spacer
Specialized Venge
Dust cap
Spacer
If anyone has some nice 3D print files of specific frame to stem transitions that would be great to share also
Thanks!
Internal routing- Dust caps + Spacers thread
If a frame is made for internal routing, the manufacturer should have the correct top covers and matching spacers. Most have locating pins that match the bars. Changing bars might require fileing off those pins and the stem shape may not match the spacers.
