My first road bike, a Look 785 Huez build
lukaszzsch
by lukaszzsch
HannibalLecter wrote:really nice, thank you. I got a good deal as well but not as good as yours, 1500 for frameset, seatpost, bits and pieces, axles and headset.
On another note, the dt hub bearings have a rough spot in the rotation, probably I will swap them. Has anyone encountered this?
And also, I am searcing for pillar xtra lite titanium spokes, but no luck.
By the way, what wheels are you running? nice weight
Hi,
I had very good experience with Aeolus xxx4 and decided to buy Aeolus xxx2 for my „mountain setup”
More pictures:
HannibalLecter
by HannibalLecter
very beautiful bike you have there. I will go with the yellow tape as well. And you reverse started it so it ends on the bar plugs, really nice.
Some updates on my wheel rims and some photos of my pump, a very nice SKS
lukaszzsch
by lukaszzsch
It’s my first time with reversed taping and I don’t recommend surely. Tape curls up messily.
But generally trial was worth almost nothing - this yellow ribbon cork tape costs 4 Euros
HannibalLecter
by HannibalLecter
I may try the reverse tape tecnique, see how I like it. On another note, my Light bicycle rims have just been shipped from China, so I hope I will start the wheel build soon.
So, some questions.
Has anyone used the titanium pillar spokes? I want to try them for the weight savings, even compared to CX Rays, but they seem unobtainable and without any lengths available.
Second, I would like to buy interior spline wolftooth lock rings for my discs, but a friend of mine has similar shimano ones on dt e1800 wheels and in the front I think, the tool doesnt engage enough with the lock ring.Is this the same with dt 240 exp hubs? should I go for external splines?
HannibalLecter
by HannibalLecter
Sun Mar 24, 2024 4:46 pm
So, some questions.
bump because I really can't find titanium spokes
Nickldn
by Nickldn
Curious why you want to use titanium spokes as a retrofit. Theoretical weight saving sounds good, but any concerns about change in overall wheel stiffness and impact on comfort/power transfer?
I hear that with carbon spokes the stiffness is usually greater than steel so using the same number of spokes on the same design of rim results in a much stiffer wheel (less comfort). This is why some carbon wheels use fewer spokes.
Does the same issue apply to titanium spokes?
Shadco
by Shadco
There is just something about Look and Campy that is hard to resist. And I am a big fan of cup and cone hubs.
785's are very nice.
HannibalLecter
by HannibalLecter
Nickldn wrote:
Thu Mar 28, 2024 2:21 pm
Hello
I don't want to retrofit with titanium spokes, my wheelset isnt built yet. The finished bike on this thread is not mine :)
the reason that I want to go with titanium spokes is of course primarily the weight savings and second the cool factor. I am pretty lightweight (67 kgs) and not very strong so why not.
As for your question about stiffness relatively to carbon spokes, my engineering assumption, considering the fact that stiffness is really determined by only two things, the modulus of elasticity E and the moment of inertia I in the direction that interests us (lateral to the wheel/bike because that's when the spokes bend during a corner. When the bike travels straight the spokes are getting loaded only in tension), the first is an inherent property of the material, the second is determined of the shape and area, for steel vs cfrp, the cfrp spokes will have both E and I of greater magnitude. E because of the material properties and I because they are thicker usually, they end up stiffer.
As for titanium, someone could argue that it can also be stiffer than steel, beacuse due to it's smaller E and strength (strength not specific strength/weight ratio) compared to steel, the thickness must be bigger and that could also result in stiffer spokes because of the bigger moment of inertia.
there are finer details to that analysis, but thats what I can think, without at least checking every cross section and material properties to come to the conclusion why everything works as it does.
HannibalLecter
by HannibalLecter
Shadco wrote:
Thu Mar 28, 2024 2:36 pm
the looks are awesome, I am hesitant about the bearings and also I couldnt get light enough wheels on my budget
Nickldn
by Nickldn
Thu Mar 28, 2024 3:04 pm
Hello
So do you intend to have wheels built up for you, or do it yourself?
If the former then I'm sure your wheelbuilder will be able to provide guidance on spokes and when/if titanium is suitable choice.
If you're doing it yourself then all I can say is let us know how it goes.
Personally if I was looking for light wheels I'd go for carbon spokes every single time.
HannibalLecter
by HannibalLecter
Nickldn wrote:
Thu Mar 28, 2024 8:03 pm
Hello
the latter. And I am curious on why ti spokes are not discussed more often. Carbon spokes are proven to be unreliable most of the times, as they delaminate from the metal part. Still, I don't think they are available as standalone option, are they? I would go for berg rope spokes but I wont spent 450+ euro for spokes
HannibalLecter
by HannibalLecter
Finally!
my lightbicycle AR 465 rims are here, and the quality is impeccable
HannibalLecter
by HannibalLecter
I finally built the front wheel, not tensioned yet because I don't have yet the tension meter, but it looks really cool. I hope I'll get the rear hub soon too. Feeding the nipples through the valve hole and fishing them with a magnet wasn't very pleasant though
