R785 vs R9170 Shifters
I'm working on my BMC Roadmachine build. The model came with R785 shifters, but I'm considering upgrading to R9170 shifters. Is there any difference in reach between these two? I've found mixed information in prior searches.
Co-Founder SmrT Hydration
https://smrthydration.com/
https://www.facebook.com/smrthydration
#saddlebagssuck
#saddlebagssuck
I have just gone from r785 to 9170 the reach in my opinion is approx 10mm shorter ( I am going to lengthen stem to compensate) the 9170 are so much better , be sure to change to correct hoses for the 9170 levers as they are not cross compatible (I had to get them shipped from the states as uk out of stock)
9170 levers so much lighter and better lever feel.
PaulH wrote:9170 levers so much lighter and better lever feel.
Wife's bike has 9170 and mine has R785 and the first thing I noticed when I built her bike were that the hoods/body was slightly narrower as well. Have not been able to find these in the US, but was able to order a retail box set (shifters, hydraulic hose, mineral oil) from a Japanese Ebay store and should be swapping mine out in a few days.
- Michael
PaulH wrote:Be very careful with the bleed screw as it strips easy and you can't get replacements
I read that on your other thread, so assuming you are referring to the head of the bleed port cover and not the threads themselves? Having followed the dealer manual and using a good quality 2 mm Allen key to install a set of the ST-R9170 shifters on my wife's bike, I had no issues, which really has me wondering about the quality of tools and/or the skill level of the mechanics at your LBS.
- Michael
ms6073 wrote:PaulH wrote:9170 levers so much lighter and better lever feel.
can't find them either and most ship in september.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
I don't believe there are 9000 brake calipers. As far as I know, just the R685/RS685 calipers, which are variations of the XT calipers.
boots2000 wrote:Are you guys also using the 9170 calipers?
Or are you using 685/785 or 9000?
justaute wrote:I don't believe there are 9000 brake calipers. As far as I know, just the R685/RS685 calipers, which are variations of the XT calipers.boots2000 wrote:Are you guys also using the 9170 calipers?
Yes, there a new DA calipers. F.ex:
http://cyclingmagazine.ca/sections/gear-reviews/components/shimano-dura-ace-r9100-hydraulic-disc-brakes/
Current bikes:
Scott Addict Premium Disc 2018
Scott Addict Orica Greenedge 2015
Retired:
Canyon Endurace CF SLX 2016
Canyon Ultimate CF SLX 2013
Retired:
PaulH wrote:I got mine sent from the states to uk by 365 cycles
thx. i'll look into it. not sure why its so spread thin.
- Factor LS Disc
- Factor LS Disc
Perhaps I mis-understood. The question was if 9000 calipers were used. Your link shows the 9100 series, not 9000 series.
Delorre wrote:justaute wrote:I don't believe there are 9000 brake calipers. As far as I know, just the R685/RS685 calipers, which are variations of the XT calipers.boots2000 wrote:Are you guys also using the 9170 calipers?
