Perfect, plenty of clearance for your torque wrench then? I don't know if it is just the Apto or what but it is an absolute pain in the arseGONE4ARIDE wrote: ↑Thu Jun 03, 2021 1:20 pmNo issues here. I just installed and torqued a new Pro Vibe stem last weekend with ease.Tifosiphil wrote: ↑Thu Jun 03, 2021 12:01 pmSorry to revive this one, does anyone have any issues torquing the bolts on the Pro stem? I've currently got a 3T Apto -17 which is an absolute nightmare. Is the Pro Vibe any better?
Shimano Pro Vibe Di2 stem's computer mount option.
What is the problem with the 3T Apto?Tifosiphil wrote: ↑Thu Jun 03, 2021 4:12 pmPerfect, plenty of clearance for your torque wrench then? I don't know if it is just the Apto or what but it is an absolute pain in the arseGONE4ARIDE wrote: ↑Thu Jun 03, 2021 1:20 pmNo issues here. I just installed and torqued a new Pro Vibe stem last weekend with ease.Tifosiphil wrote: ↑Thu Jun 03, 2021 12:01 pmSorry to revive this one, does anyone have any issues torquing the bolts on the Pro stem? I've currently got a 3T Apto -17 which is an absolute nightmare. Is the Pro Vibe any better?
- robbosmans
- Moderator
- Contact:
Just use an extension
It may be a combination of my setup and frame (which uses a 44mm headtube) but I run the stem slammed so an extension can't be put on the bottom bolts fully without a ball-ended socket. Tried a flexible entension and didn't like it particularly either.TonyM wrote: ↑Thu Jun 03, 2021 9:27 pmWhat is the problem with the 3T Apto?Tifosiphil wrote: ↑Thu Jun 03, 2021 4:12 pmPerfect, plenty of clearance for your torque wrench then? I don't know if it is just the Apto or what but it is an absolute pain in the arseGONE4ARIDE wrote: ↑Thu Jun 03, 2021 1:20 pmNo issues here. I just installed and torqued a new Pro Vibe stem last weekend with ease.Tifosiphil wrote: ↑Thu Jun 03, 2021 12:01 pmSorry to revive this one, does anyone have any issues torquing the bolts on the Pro stem? I've currently got a 3T Apto -17 which is an absolute nightmare. Is the Pro Vibe any better?
It's a non-issue 90% of the time but if I am out/travelling and the bars are loose I have to guess the torque which is a bit annoying as I normally carry one of the Topeak Torqbar's or one of the Sealey Digital Torque's on longer rides or trips
- robbosmans
- Moderator
- Contact:
Just remove the stem from the bike, torque the bars, problem solved
Yes. Plenty of clearance for torque wrench using an extension.Tifosiphil wrote: ↑Thu Jun 03, 2021 4:12 pmPerfect, plenty of clearance for your torque wrench then? I don't know if it is just the Apto or what but it is an absolute pain in the arseGONE4ARIDE wrote: ↑Thu Jun 03, 2021 1:20 pmNo issues here. I just installed and torqued a new Pro Vibe stem last weekend with ease.Tifosiphil wrote: ↑Thu Jun 03, 2021 12:01 pmSorry to revive this one, does anyone have any issues torquing the bolts on the Pro stem? I've currently got a 3T Apto -17 which is an absolute nightmare. Is the Pro Vibe any better?
