Looking for a 60mm Aero seatpost
samyoooo
by samyoooo
Hello i'm after a new seatpost to replace my current one which is from a DALKIIA F1 ZERO frameset or if anyone knows another seat post that fits the frame, it can be aluminum or carbon, aluminum preferred
By looking at this review it appears to be a 60mm (clamp?) seatpost
http://www.bikeradar.com/...ia-f1-zero-tt-28277/
samyoooo
by samyoooo
bump
BeeSeeBee
by BeeSeeBee
That's very likely a post designed specifically for that frame, so you're not likely to find anything in stores that would fit. You could try a carbon repair place if you need it repaired. From other of yours posts I found, you've been looking for a while!
It looks like Ciclismo was the distributor (no idea who they are), but it looks like it was an open mold frame, so it may be a bit hard to track down the part from the right manufacturer.
Rudi
by Rudi
I'd wondered at the time whether they were the same frame as the Planet X Steath, but on another look I think not. Very similar seat tube cut outs though:
http://www.google.co.uk/url?sa=i&rct=j& ... 1183411340
http://www.google.co.uk/url?sa=i&rct=j& ... 1398524904
Have you tried finding what the open mold frame model was? That might be your best bet.
Edit: £21 on planet X. Are these photos close enough for a punt:
http://www.planetx.co.uk/i/q/SPPXSPCTV2 ... ack-frames
Cervelo R3 - 5.4kg viewtopic.php?f=10&t=142420
samyoooo
by samyoooo
Apparently they are the same as Onyxx Alexo Tt bikes
Planet X posts are 81mm
thumper88
by thumper88
if it's broke, may be fixable.... calfee etc or a do it yourself depending on the nature of the problem.
samyoooo
by samyoooo
thumper88 wrote:if it's broke, may be fixable.... calfee etc or a do it yourself depending on the nature of the problem.
ITs already been repaired before. More so a Bodge. But I would like to start the season with a safer one
