Remove guts from Super Record brifters?
Current generation Super Record mechanical brifters are 342g for the pair. Does anyone know the weight with the shifting guts removed? Before I go ahead an order some for the sole purpose of gutting them.
Is there a lighter option for a standalone brake lever that is still remotely ergonomic? Does tuned gutted Red work out to be lighter?
What tuning is possible on the SR levers besides drill/dremel and BTP clamps?
By the way, does anyone have any BTP clamps they want to sell, or know where they may be available under a different name? (Also looking for BTP downtube shifters should anyone wish to part with theirs.)
Thanks
Thanks
Thing is very do-able.
left shifter internals weight 62 grams incl grease. So both could save you around-ish 130g.
But visually... disaster
Mark Twain
I can be wrong, and have plenty of examples for that
Mark Twain
How about original Campag 10 speed brake levers - same shape as the previous Ultrashift.
I would go lower down the range to centaur/Athena. The powershift levers have fewer smaller cut-outs on the lever so it remains more comfortable for the hands. I did this for my commuting bike and can weigh the internals when I get home. (Also cheaper for something you're going to pull apart anyway!)
I did the left lever on my Pantani Replica. It's Record but the lever is now brake only as he used a downtube shifter. I did weigh the parts but can't remember the exact weight. It was less than expected. I've still got everything bagged up so I'll check it when I get home!
ghisallo2003 wrote:How about original Campag 10 speed brake levers - same shape as the previous Ultrashift.
This is the correct answer with just one slight hitch, they're discontinued. Here is a used set on ebay:
http://www.ebay.co.uk/itm/Campagnolo-RE ... SwPc9W0LOl
cycling / nature / music
- bikerjulio
ghisallo2003 wrote:How about original Campag 10 speed brake levers - same shape as the previous Ergopower
FIFY
note to OP. Only Campy trolls use the B word. And you're not a troll are you?
There's sometimes a buggy.
One.
One.
Shimano 9070 Di2 levers weigh 230g, but if you remove the electronic part they weigh ca. 200g for both.
Campa SR EPS weigh around 265g and you can probably remove the electronic parts from them also.
~210gr for the 11sp and ~240gr for the 10sp levers. You need to get some foam to fill in the huge gaping cavity after gut them too, so add another 10gr for that.
Or just get the SRAM brake levers and be lazy, which I ended up with after all the fiddling. Also nice to be able to adjust the lever reach.
Off topic.... fill me in on why no one should call brake/shift levers "brifters".
Did that fall out of style, and now all the cool-kids call them something else?
- bikerjulio
BikeAnon wrote:Off topic.... fill me in on why no one should call brake/shift levers "brifters".
1. It is an ugly made-up word that no one uses in conversation.
2. Show me any manufacturer or professional or journalist using the word. They don't for a reason. It sucks and reeks of newb.
3. The word just sounds lame and was never in style.
4. Shimano may use one lever for both shifting and braking, but not Campagnolo, making the word especially objectionable to Campyphiles.
One.
One.
I appreciate the replies and ideas. Still leaning towards new Campy because it has better ergonomics than Red and definitely than older Campy. The SR levers sound like they'll finish with as low a weight as any.
stormur, I believe the aesthetics will be fine as the brake lever makes a nice shape in its own right. As far as I can tell, the only missing visual element is the shift paddle, which is not essential visually.
Thanks, interested to hear what you measure it as
Interesting idea. The electronic guts weigh much less than the mechanical guts do, so probably finish with a similar weight. Anyone tried this at all?
I've heard of people filling the gaps with a few well-placed layers of carbon and resin, something I know nothing about doing, but would love to learn.
Harmitc wrote:I did the left lever on my Pantani Replica. It's Record but the lever is now brake only as he used a downtube shifter. I did weigh the parts but can't remember the exact weight. It was less than expected. I've still got everything bagged up so I'll check it when I get home!
LAN wrote:Shimano 9070 Di2 levers weigh 230g, but if you remove the electronic part they weigh ca. 200g for both.
thp wrote:~210gr for the 11sp and ~240gr for the 10sp levers. You need to get some foam to fill in the huge gaping cavity after gut them too, so add another 10gr for that.
- Stolichnaya
Check the ergonomics on the TRP RRL SR levers. Might those work for you?
They are not super light but look good and are plug and play. Seems like you could tune those further to save some extra weight.
Campagnolo has Ergos. Not brifters... Ergos.
Miller wrote:ghisallo2003 wrote:How about original Campag 10 speed brake levers - same shape as the previous Ultrashift.
I have two sets of these gathering dust. Let me know if interested.
