Has anyone serviced/rebuilt their EEcycleworks brakes? I have the circa 2013 model and i noticed that lever feel is now fairly mushy and not as snappy as it used to be. I thought it was cabling but even after changing cables/frames it is still the same.
Would appreciate if anyone have instructions or some step by steps?
All i could find was the installation instructions.
http://eecycleworks.com/en/wp-content/u ... ings-2.pdf
servicing eecycleworks brakes?
The return springs being titanium are not really that strong, so you could take them off and try bending them out a little by hand, it's a 10 second job. pUll one side out, twist and pull the other, bend and replace.
Other than that, mushiness will be down to cables...... The pivots should not be worn but if they are, you'll need to contact Craig at EE...... He's a very helpful guy.
