chain lube
I've used most of the popular ones over the years. Currently Chain-L for the summer and just FinishLine wet lube on my commuter - SS so just a basic chain and something to keep it fairly smooth.
I'm just about to try waxing my summer chain. Got an old crockpot and a pile of wax pellets. I'm definitely a fan of a clean chain so I'm interested to see how it works.
I'm left handed, if that matters.
grouk wrote:where do you get it?
http://www.wd40bike.com/where-to-buy/ or many on-line places or your lbs
the KMC lube I've found to be the best.
J EURO
- Resident master of GIF
- Contact:
canoas wrote:Phil Wood Tenacious oil.....been using since early 90's
as chain lube?!?! wut. isn't this for bearings and pivots
re: nixfrixshun. They probably won't disclose the ingredients as that's literally their secret sauce.
been meaning to try some but overseas shipping cost kills it for me. Will pick some up next time I'm in the states.
been using progold myself for years. Does a good job cleaning the chain too.
nathanong87 wrote:canoas wrote:Phil Wood Tenacious oil.....been using since early 90's
its a wet lube you could say. I chose to run on my chains and other parts during the whole year. Jockey Wheels work excellent with Tenacious. Put it on the chain and it stays on! Used @races over almost 3 decades. Chains last a long time if lubed with Tenacious. I've never changed, only if my LBS is out of stock then I'll buy something else! You don't need to oil as much as the old days as there's less metal-to-metal contact.
canoas wrote:nathanong87 wrote:canoas wrote:Phil Wood Tenacious oil.....been using since early 90's
Out of curiosity, do you regularly scrub/jetwash/degrease or otherwise clean your chain, or does a simple wipe down before/after relubing do the trick? I know protour mechanics will often use actual bearing grease on chains but they are cleaning/degreasing with diesel fuel and jet washes on a near daily basis so a lube's propensity to accumulate grime is not really a concern, but most of us will use a thinner lube in order to minimize any need for that.
Also, what did you mean about less "metal-to-metal" contact than in the old days? Did you mean narrower chain width used for 11spd has less surface area or what?
Thank you in advance for the clarification.
