d36
by d36 on Sat Mar 16, 2019 4:21 am
Klaster_1 wrote: ↑Sat Mar 16, 2019 3:25 am
d36 wrote: ↑Sat Mar 16, 2019 2:22 am
I think my 80mm stem is actually 85mm long
My 60mm is 65mm.
Haha
Thanks!
That solves 1 fit problem
Now I gotta figure out how to reconcile the 4cm length difference between my sram and shimano shifters
biwa
by biwa on Tue May 28, 2019 6:01 am
Reading the posts above, can anyone confirm these stems are in fact 5mm longer than spec'ed? E.g. a marked 90mm is actually 95mm?
hannawald
mrlobber
by mrlobber on Tue May 28, 2019 7:58 am
130mm (I have several) have been around 130mm, as expected.
Marin
biwa
by biwa on Tue May 28, 2019 11:09 pm
Great article, thanks! It seems +/- 3mm from the spec'ed length is common in the industry by nature of manufacturing, and +/- 5mm is possible for lower-end products.
Marin
posaunemeister
by posaunemeister on Sat Aug 17, 2019 3:22 am
addictR1 wrote: ↑Fri Sep 01, 2017 4:05 am
Just picked up my 4th Uno Kalloy stem. I love it! Picked up gold Ti screw using my eBay buck. Pretty light for a 90mm 17degree.
Wow. I have a similar model, but at a 7 degree angle and 80mm, and it comes to 100g on the dot. I'm curious to know the reason for the huge disparity in weight.
"When I was young, I admired clever people. Now that I am old, I admire kind people." - Abraham Joshua Heschel
addictR1
by addictR1 on Sat Aug 17, 2019 7:30 am
posaunemeister wrote:addictR1 wrote: ↑Fri Sep 01, 2017 4:05 am
I’ve seen that as well. It depends on which seller you buy from. I too also have a 85mm one that is same weight as my 110mm.
addictR1
by addictR1 on Sat Aug 17, 2019 11:23 pm
Marin wrote:Are you both sure the heavy stems are the "7" model?
On mine the logos are all the same before I stripped it. Just from different sellers.
pdlpsher1
by pdlpsher1 on Sun Aug 18, 2019 12:45 am
I’ve also observed slight differences in weight. I have the 100, 110, and 120mm stems. The 120 is lighter than the 110. Go figure. When I tap on the 120 it rings as if it’s thinner than the 110.
Are you guys with Ti bolts on the steerer clamp finding that it holds the steerer tightly? I have tried Ti bolts but find the headset eventually loosen over time. Put stainless bolts on and no slippage. I do use Ti bolts on the handlebar clamps and no issues there.
addictR1
by addictR1 on Sun Aug 18, 2019 3:49 am
pdlpsher1 wrote:I’ve also observed slight differences in weight. I have the 100, 110, and 120mm stems. The 120 is lighter than the 110. Go figure. When I tap on the 120 it rings as if it’s thinner than the 110.
I use Ti bolt. But I also use carbon paste for the steerer section. My bars are Zipps so no paste there.
The only issue I had with gold bolts is it breaking when I torque it to 4.5nm. Could be my clicker type of torque wrench isn’t the most accurate. Now I just torque to 4nm and still no slip.
pdlpsher1
by pdlpsher1 on Sun Aug 18, 2019 4:40 am
Mine was quite dry but now I have loads of carbon paste but I still prefer to stick with steel bolts.
Yeah I’ve also broken 4mm Ti bolts at around 4nm. That’s why I’m sticking with steel bolts for the steerer clamp. I bought an electronic torque meter that I use to calibrate my automotive torque wrench. I also use it to calibrate my bike torque wrench.
addictR1
by addictR1 on Sun Aug 18, 2019 4:56 am
Do you have a link to the electric torque calibration tool? I have some snap on torque wrench that could use some checking too.
